grid heater
Old Dec 15, 2009 | 07:48 PM
dshane62's Avatar
Default grid heater
does anyone know if the computer on 95 controlls the grid heaters
mine quit but so did the speedo,tach,a\c cycling,and quit charging.
i fixed the charging but everything else still dont work
i did the codes off computer but that dont help cuz the only ones i got was tran temp sensor, and tps which i took the auto tranny out and i dont use the tps it just lays there hanging. i dont get any codes that you would expect if the computer was bad i dont even
get any about not charging i checked all the grounds and fuses. added a ground strap
from box to cab and engine to frame. the engine speed sensor isnew and so is the vss on the tranny thanks for any thoughts
Old Dec 15, 2009 | 09:29 PM
smokincummins92's Avatar
Did all this stuff quit at once or did they quit one by one? The grid heater is controled by the computer and the relays for it are located in the engine compartment, bolted to the left inner fender below the left battery. Sounds like you have a ground problem or a circuit in the computer is screwed Anybody else have an idea???
Old Dec 15, 2009 | 10:16 PM
dshane62's Avatar
i think its in the computer but when i ran the codes you would think it have other than what i got off it. the tach, speedo,a\c all quit at once im not sure when the charging quit
cuzi got 3 batts anyway thanks i pulled the computer and all the jelly like **** in one area
was all cracked like it was hot and there is a cap. that looks not so good but i just put it back for now cant go buy one right now and i wont if there is a way around it
Old Dec 16, 2009 | 07:50 AM
STUMPMAN's Avatar
Check to see that the heater grid has no breaks in it, use the multimeter
Old Dec 16, 2009 | 08:00 AM
12vcummins96's Avatar
its your computer
Old Dec 16, 2009 | 10:31 AM
PhilipR's Avatar
If the CPS is dead the PCM will shut down as it doesn't think the truck is running. Before you run out to buy a new PCM check the CPS gap and make sure it's bad first.
Old Dec 16, 2009 | 05:53 PM
dshane62's Avatar
the gap is 0.50 right?
the sensor is new but to tell the truth i just set it real close to the dampner didnt gap it
i will check it i hope thats it but i dont get that lucky
Old Dec 16, 2009 | 06:03 PM
PhilipR's Avatar
correct....it's worth a shot to check it out.
Old Dec 19, 2009 | 05:21 PM
dshane62's Avatar
well i checked the gap and reset it to .50 still no good didnt change anything
thanks cuz ya never know
im thinking computer. hell if i could wire around it for the speedo and tach to work i wouldnt even mess with it
dodge2014
Apr 16, 2015 08:54 PM
95 cummin
Jan 21, 2015 11:54 AM
Rooster24v
15
Jan 4, 2015 08:20 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
justinsbeck
Nov 22, 2014 03:03 AM
