Diesel Performance Plus, LLC Visit - Diesel Performance Plus. LLC
Glow Shift 3 in 1 Combo Gauge
Old Dec 15, 2009 | 03:42 PM
DppPower's Avatar
Default Glow Shift 3 in 1 Combo Gauge
I sell a ton of Glow Shift gauges and I just got a call from my Rep at Glow Shift and she told they have a new gauge they just released today.
3 in 1 Combo Gauge - Boost, Exhaust Temp, Temp Readings
Price on these is $169.00
GlowShift’s newly released 60mm 3 in 1 Combo Gauge allows you to easily monitor some of the most vital engine readings while allowing you to select from over ten backlighting colors designed to match your vehicle’s stock gauges. This unit will allow you to read boost pressure up to 60 PSI, exhaust temperature up to 2200 degrees Fahrenheit as well as a choice of oil, coolant or transmission temperature up to 300 degrees Fahrenheit. Boost pressure, exhaust and temperature sensors are all included. Select from ten bright backlighting colors as well as two color cycling modes including a color fade and color cycle feature. By bringing three meters into one gauge, this allows for a reduction in the amount of space needed for automotive gauges in your vehicle’s interior and at the same time allowing you to observe your engine more readily in one well designed compact unit. Install the included temperature sensor to either your oil, coolant or transmission senders to effortlessly monitor it using the digital temperature readout on the unit itself. Each package also includes a gauge pod to mount the unit on your dashboard. Each gauge includes GlowShift’s standard one year limited warranty as well as free technical support.
•60mm black face gauge with magnified tinted lens
•10 color LED backlit illumination with color recall technology
•Digital readout
•Includes boost pressure, exhaust and temperature sensors
•1 year Warranty & Free Technical Support
If you have any questions please fell free to Call, PM or email me.
Old Dec 15, 2009 | 04:40 PM
captain_stabbin's Avatar
kewl
Old Dec 15, 2009 | 05:03 PM
biged681985's Avatar
is this the only 3 in one they are offering or will they have different combos for like oil press, water tempand so on?
Old Dec 15, 2009 | 05:14 PM
DppPower's Avatar
This will be it for now. They are working on others but I have no clue when they will be releasing them.
Old Dec 15, 2009 | 05:15 PM
Benjamin's Avatar
Bombardier
what about 0-100 psi for boost instead of 0-60psi?
Old Dec 16, 2009 | 09:17 AM
DppPower's Avatar
I will mention this to them...
Metz1234
Mar 3, 2016 10:20 PM
rkp209
Chevy/GMC Duramax 2011 LML
Jan 10, 2016 10:32 AM
Texasthb
Mar 4, 2015 08:20 AM
ajwright64
Feb 4, 2015 09:36 PM
norcal6.5
Dec 7, 2014 07:04 PM
