Clutch Replacement
Old Dec 15, 2009 | 10:11 AM
94cummins12v's Avatar
Default Clutch Replacement
last night i pulled my tranny out so i can put my new clutch in. i was able to pull that tranny out withh nothing but 2 ratchet straps an my hands. i pulled the tcase off an dboth drivelined. i left the cross member in. i unbolted the 4 bolts that hold the tranny to the bell housing and slid the tranny back 14 inches resting it on the cross member using the ratchet straps as a cradal
Old Dec 15, 2009 | 11:18 AM
94 12valve's Avatar
you took your trans out with two ratchet straps and left the cross member in? are you posting this to try and impress us?
I just have one question ... why?
I'm a firm beleiver of the "work smarter not harder" saying and here is my advice to ya ... Go to wal mart buy a cheep floor jack, and drop the cross member and slide it out like your suposed to. It will make life way easyer when you try to put the trans back in.
Old Dec 18, 2009 | 09:07 AM
oh it made it 10 times easyer than pulling that stupid cross member abd dropping it on the floor
Old Dec 18, 2009 | 11:12 AM
94 12valve's Avatar
the cross member is easy to pull and replace
Old Dec 18, 2009 | 12:21 PM
12vcummins96's Avatar
i hate those damn crossmember
Old Dec 18, 2009 | 03:06 PM
94 12valve's Avatar
the best way I have found is to remove the rubber peice that connects the cross member, use a rubber hammer to hit the cross member up as far as you can, and slide it out.
OR use a jack to spread the frame rails appart slightly and it will fall out
Old Dec 18, 2009 | 03:29 PM
PhilipR's Avatar
I have a cheap Porto-Power from Harbor freight that I picked up when I did my trans to pull the cross member.....mad things much easier and it's a nice tool to have in the garage.
Old Dec 19, 2009 | 09:37 PM
they arent easy to pull at all there some trucks ive spent a good hour fighting that and there is no point pulling the crossmeber and tranny all the way out if you dont have to
Old Dec 19, 2009 | 09:39 PM
94 12valve's Avatar
I just told you how to do it the easy way ... after I take the drive shafts off it takes under 10 min to get the cross member off
Old Dec 19, 2009 | 10:57 PM
mtzrpr's Avatar
i dont see how its possible, everytime ive ever pulled a nv you have to drop it some to get the shifter housing down below the floorboard. i have a porta-power it makes this job ALOT easier.
