Seaching for cheap Hp
Old Dec 15, 2009 | 12:08 AM
dieselpower's Avatar
Default Seaching for cheap Hp
Hey guy looking for soom quick help taking the truck in for some tuning witch includes advancing the timing to 15.5 and doing some pump fine tuning, but my problem is thy say 275hp is as far as thy say is safe for stock turbo. I would like a little more power and dont have money for a new turbo so im wondering what can add some safe hp with not hurting mpgs. I was kind of thinking 3k-4k gov kit that includes both not sure witch to run was told 3k if I dont have 60lb valve spring but not sure if thats more cost effective than something else. I will be glad to get some input on what you guys think
Old Dec 15, 2009 | 12:46 AM
12valvetater's Avatar
My truck dynoed 320/700 with a stock charger, 370s and a #4 plate.
Old Dec 15, 2009 | 01:12 AM
what kind of egts do you run if you haul a load up some hills
Old Dec 15, 2009 | 06:56 AM
PhilipR's Avatar
4K kit all the way. It fuels harder. Do you have an auto or a manual trans?
Old Dec 15, 2009 | 10:55 AM
its A auto thats been went through and has a bd valve body
Old Dec 15, 2009 | 10:57 AM
PhilipR's Avatar
What does "Went Through" mean? Do you have a stock converter? billet input shaft or other shafts? Increased clutch counts? Stock or aftermarket clutches?
Old Dec 15, 2009 | 11:30 AM
Sorry Ill be more descriptive it has a bd valve body, and a deep magteck pan with a heavy duty torqu converter not witch is rated for 350hp and it has heavyduty clutches and bands but no billit input shaft was new to auto trannys allways owned sticks and wish I stuck with them
Old Dec 15, 2009 | 11:34 AM
PhilipR's Avatar
So no boosted launches.....is the converter a billet cover with a big single clutch or atriple stock clutches?
Old Dec 15, 2009 | 12:58 PM
Single clutch but I dont no about the billit cover need to call trans shop for more info on it
Old Dec 15, 2009 | 05:20 PM
monster12valve's Avatar
4k kit... u dont need the 60lb springs if u dont rev past 3k. it being an auto u prob never hit 4k anyhow... but i do recommend the 60lb springs if you can swing them.
