P0261 & P0263 Trouble Codes-Truck Running Bad
Old Dec 14, 2009 | 03:02 PM
Powerstroke's Avatar
Default P0261 & P0263 Trouble Codes-Truck Running Bad
My F-250 is running very bad, rough idle, and runs very bad when I hit 40+ MPH it feels like the truck is shaking.
I took the truck to a local mechanic and he put it on a machine and it spit out the codes P0261 & P 0263. He said it had something to do with Injector Circuit Low Cyl. 1, and Cyl 1 Center Balance Fault.
Does anyone know what any of this means? The mechanic thinks it might be a bad Cyl 1 but he is not for sure, nor does he have the expertise to work on it.
The truck was running just as fine as ever until Friday when it started acting up all of a sudden. I was kind of thinking it might be a bad or weak FICM. I have already changed the MAF sensor about 6 months ago, changed the ICP sensor 6 months ago, and I changed the EGR about 1 year ago.
Any suggestions...
Thanks in advance,
Joe
Old Dec 14, 2009 | 04:10 PM
wildbill's Avatar
Not sure, but it's probably a bad injector.
Old Dec 24, 2009 | 01:33 PM
Diesel Nut's Avatar
Injector cir low indicates possible FICM issue or wiring to the injector. Possibly the injector itself, but I would check wiring first. Pop off the valve cover and inspect the wiring on the injector.
Old Dec 26, 2009 | 07:21 AM
Big Angry Hillbilly's Avatar
Injector circuit codes are generally indicators of a FICM on the road to failure. Monitor the FICM_MPWR pid while the engine is running, should be at or around 48v.
jjbced
Jul 19, 2015 10:03 AM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
