Turbo upgrade
Old Dec 13, 2009 | 06:41 PM
dieselpower's Avatar
Default Turbo upgrade
was looking into turbo upgrade for my 97 12v and cant deside what would sute my goals best. what im looking to do is to have a 350hp to 450hp fun daily driver that spools fast, and a truck that can haul a 18,000lb 5th with out heat issuses. I've looked at the hx40/35 12cfm hybrid kit and turbonetics because it is ballbaring turbo that should spool faster and have better power capeobility. So what do you guy think would be the best turbo for my needs
Old Dec 13, 2009 | 06:58 PM
12valvetater's Avatar
Call E.D. they'll be able to get you all sorted out. A 62/65-13 or something around there.
Old Dec 13, 2009 | 07:50 PM
Shea@L&N Performance's Avatar
FormerVendor
As stated above 62/65/13, 68/68/13 would work out great for ya. Also check out BD's super B turbo, which is a 62/68/13 IIRC.
Old Dec 13, 2009 | 08:22 PM
thanks for the info guys do you have the number for him, and do they spool as fast as stock or faster
Old Dec 13, 2009 | 11:25 PM
Chris at engineered diesel, 616 608 2977.
Spool up time will have alot to do with how well you have your pump tuned. If this still isn't enough you can port the exhaust manifold, head and install a cam.
Last edited by 12valvetater; Dec 13, 2009 at 11:25 PM. Reason: Automerged Doublepost
Old Dec 13, 2009 | 11:48 PM
thanks I hope to get one soon and couple it with ddp 75hp injectors and a 3 or 4gsk kit and have it dyno tuned at ddp local shop her in monroe wa they seem to be agood shop
Old Dec 14, 2009 | 02:00 AM
There are better choices than DDP injectors I would go with a set of SDX 5x.012s
Old Dec 14, 2009 | 06:02 AM
94 12valve's Avatar
the super b is an s300g 57/65/14 the special is a 64/71/14
Old Dec 14, 2009 | 09:29 AM
Do the sdx 5x.012 smoke bad or do they run clean I dont want a cheap part thats not as smooth as the ddp injectors what is the hp rating on them
Old Dec 14, 2009 | 09:42 AM
FormerVendor
Hell I wasnt even close, thanks for the correct info 94
SDX makes some great injectors, send jamie or chris a pm and they will get ya sorted out
Last edited by Shea@L&N Performance; Dec 14, 2009 at 09:42 AM. Reason: Automerged Doublepost
