bottom end
Old Dec 12, 2009 | 03:32 PM
6btsmoker's Avatar
Default bottom end
Long story,short version; I need a crankshaft for my 98 12v.
What is out there ? Thanks for any help.
Old Dec 12, 2009 | 03:42 PM
94 12valve's Avatar
whats wrong with the stocker?
Old Dec 12, 2009 | 04:20 PM
6btsmoker's Avatar
The head gasket blew.Then i had the head fire ringed.On the ride home from the shop it started to lose power,a couple of seconds later it started knocking and lost oil pressure.
My wife was driving behind me and said it put out a puff of smoke just before it lost power and i pulled over.I think the bottom end has had it now.Merry Christmas.
Old Dec 12, 2009 | 04:36 PM
ArizonaRedneck's Avatar
i wouldnt jump to any conclusions just yet before pulling it down and checking it out could be and probably is still salvageable. and in your explanation of what happened iam confused where bad crank comes into the picture
Old Dec 12, 2009 | 04:42 PM
6btsmoker's Avatar
The loss of oil pressure and the knocking,sounded like the bottom end.I think it spun a bearing.I am hoping for the best,but trying to be ready for the worst.
Old Dec 12, 2009 | 04:58 PM
okay i understand now but check it out and let me know how you came out on the deal not good that is abummer
Old Dec 12, 2009 | 05:21 PM
6btsmoker's Avatar
Thanks.
I don't usually run the truck in the winter,but the head gasket blew late this fall and was just picking the truck up from the shop.I may not have any infor for a few weeks.I forgot to mention that the radiator had oil in it agin after the blow up. This is a very sad day.
Old Dec 14, 2009 | 09:49 PM
Diesel Nut's Avatar
WEll, usually the knocking and loss of oil will make the piston scrub the cylinder walls before you spin a bearing. Get it torn down but I bet your crank is fine. Just needs to be balanced and polished. If need be you can have it ground and get oversized bearings. If not, let me know, I have a 24V crank sitting in the engine room. I am pretty sure its the same.
Old Dec 15, 2009 | 07:11 PM
6btsmoker's Avatar
Thanks.Right now i'm waiting to hear from the shop as to the extent of the damage.I just hope my twins are OK.I've got too much money into this truck.Thanks for the reply,JB
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
Machinist
Jun 23, 2015 06:57 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
Cumminsman911
9
Nov 1, 2014 04:07 PM
