Lowering?
Old Dec 12, 2009 | 12:20 PM
thirdstreettito's Avatar
Default Lowering?
Anyone know how to lower a 91 D350 Reg Cab Dually?
Old Dec 12, 2009 | 03:01 PM
ArizonaRedneck's Avatar
check these out and see if it helps https://www.dieselbombers.com/5-9-li...t=lowering+rig by nccummins
Old Dec 12, 2009 | 03:09 PM
Thanks, but Im hoping to find something somewhat year specific. I may just have to do a full bag setup in the rear, with big firestones.
Old Dec 12, 2009 | 03:21 PM
muskrat's Avatar
Try this one... second page.
https://www.dieselbombers.com/1st-ge...cummins-2.html
Old Dec 12, 2009 | 03:25 PM
Cool, thanks. I want to make sure I keep the payload.
Old Dec 12, 2009 | 03:37 PM
muskrat's Avatar
Yeah, the factory puts as many leaves in as there should be for a functional truck. Keep track of your progress and take pics. Good luck!
Old Jan 4, 2010 | 12:44 AM
440warwagon's Avatar
On mine I cut 1 coil off the front spring on a cummins I'd try 3/4 of a coil.(I didn't like the heat idea!) On the rear I flipped the front mount and added 4" to the rear shackle.The pinion angle is crap and wheel hops under acceleration.The axle housing sits way to close to the frame for heavy loads.I would try 2". On my friends 1/2 ton we put the rear axle on top of the springs and used Mopar car 8 3/4 shock plates.The stock shock's worked and we were able to set the pinion angle.The axle is also too close for any load and we are going to notch the frame. These trucks are a 74 and a 87 and have a similar frame and spring design just lighter duty.
