OBD CODES P2127 AND P0483 0N 2004 3500
Old Dec 11, 2009 | 07:57 PM
jd2510's Avatar
Default OBD CODES P2127 AND P0483 0N 2004 3500
I KEEP GETTING THESE 2 CODES IN COLD WEATHER THEN THAY GO AWAY AFTER A DAY ARE SO . I KNOW THE PO483 IN THE CLUTCH FAN WHAT DO I CHECK FOR THE P2127
Old Dec 11, 2009 | 08:04 PM
wildbill's Avatar
P2127 - Apps 2 Voltage Too Low
APPS
ECM
(K29) APPS NO. 2 SIGNAL CIRCUIT OPEN
(F856) APPS NO. 2 5-VOLT SUPPLY OPEN
(K29) APPS NO. 2 SIGNAL CIRCUIT SHORTED TO GROUND
(K29) APPS NO. 2 SIGNAL CIRCUIT SHORTED TO OTHER CIRCUITS
(F856) APPS NO. 2 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
(F856) APPS NO. 2 5-VOLT SUPPLY CIRCUIT SHORTED TO OTHER CIRCUITS
INTERMITTENT CONDITION
Remove the connection under the hood (the APPS is on top of the CP3 pump, drivers side) and clean it up, then let it dry.
Old Dec 11, 2009 | 08:12 PM
jd2510's Avatar
THANKS I WILL GIVE IT A TRY
Old Dec 20, 2009 | 06:09 AM
haring164's Avatar
im having the same problem and have checked the connection on the cp3 pump multiple times with no sucess as well as replace the entire accelerator petal unit with. any ideas where to go next?
