24 valve stumbling
Old Dec 11, 2009 | 04:07 PM
mopar440cu's Avatar
Question 24 valve stumbling
I have a 01 24 valve and the problem is when I give it full throttle it seems to want to stumble like its lacking fuel. I already have a Fass 95 electronic fuel system, replaced the fuel filters and checked the check valve on the return line on the vp-44. I dont have a guage unfortunatly but, are looking on getting one. Any clues on what the stumbling can be coming from. The mechanic down here says he thinks its either the orffice tubes and o-rings, or a check valve somewhere....but what other check valves are ther in the fuel system?
Any info would be much appreciatted!!!
I forgot, also, can I put a mechanical fuel pressure guage from auto meter on this truck from Summit or do I have to have a special guage??
Last edited by mopar440cu; Dec 11, 2009 at 04:08 PM. Reason: Automerged Doublepost
Old Dec 11, 2009 | 04:30 PM
Jolleyman's Avatar
You don't need a special gauge but you will need a tapped banjo bolt and a pressure snubber to plumb into the fuel system either at the VP44 or at the fuel filter. There are plenty of older posts on how to hook the FP gauge up.
Sounds like a VP problem but its hard to eliminate things without first checking your fuel pressure and checking for any error codes. I'd start there and see what you get.
Old Dec 11, 2009 | 10:41 PM
RAW's Avatar
RAW
Fuel PSI is a must! Any DTC's? Checked APPS adjustment? Restricted airflow? Sensors clean?
You can drill and tap the banjo bolt yourself, just make sure it is SUPER, EXTRA clean before reinstalling.
Old Dec 14, 2009 | 12:48 PM
c-power ram's Avatar
is the check engine light on?
Old Dec 14, 2009 | 12:57 PM
wildbill's Avatar
https://www.dieselbombers.com/24-val...formation.html
What to look for if the CEL is on.
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
