Off Roading Diesel Discussions of Off Roading , Set Up , Designs , Practices , Techniques , Tips Including Trail Riding , Rock Climbing , Mud Bogging And More
axle swap GM to Dodge dana 44 and 60
Old Dec 10, 2009 | 11:01 PM
demodriver2X's Avatar
Default axle swap GM to Dodge dana 44 and 60
I have been told that there is different widths between the dodges and GMs axles. I have put GM axles in a couple power wagons without any problems but I was recently told that the dodge axles are a bit wider. Have I been lucky enough that the bushings where ***** out enough that the axles would go in or are these guys nuts that are telling me this? I am referring to the 93 and older dodges and the 87 and older chevys.
Old Dec 11, 2009 | 10:29 PM
ArizonaRedneck's Avatar
dunno but i thought that either the 44 or 60 was the same no matter which vehicle it was under maybe i am wrong
Old Dec 12, 2009 | 05:34 AM
yj junker's Avatar
You are wrong 44 and 60's come in many different width's but to answer the question on if the dodge and chev are different it is quite possible they are but chev made diff width axle over the years
Old Dec 12, 2009 | 11:12 AM
i am wrong thats cool as long as demodriver gets an answer thats all im worried about so this ones for you yi junker
Old Dec 17, 2009 | 04:26 AM
93_Fummins's Avatar
Are you talking about different widths hub-to-hub or pearch-to-pearch? Because those are two different issues in themselves...
Old Dec 17, 2009 | 07:01 PM
jbrown1132's Avatar
i've been wondering what would be a good donor axle for the front of my truck as well. the ifs rides good but i would like to do a solid axle swap someday.
Old Dec 19, 2009 | 10:47 PM
I was referring from perch to perch. I just got a old international in today that I thought might be a good axle donor also. It has a dana 44 with really low miles on it.
Old Jan 1, 2010 | 06:36 PM
CHEMMINS's Avatar
The difference in chev and dodge dana 60's are 1/2". The dodge 60 is narrower. But because the dodge springs are 2.5" wide and the chevs are 3" wide, you can offset the spring bushings to get the dodge axle to line up properly when using 2.5" wide springs.
Old Jan 7, 2010 | 06:26 AM
Heavy's Avatar
I run a dodge 60 in my 87 chevy and it does great it is about a 1/2 inch narrower then a chevy 60 but Ive never had a problem with it
Old Jan 7, 2010 | 05:25 PM
kazairl's Avatar
Just about everything you want to know about the Dana 60
Pirate4x4.Com - Extreme Four Wheel Drive
