Front axle poping
Old Dec 10, 2009 | 08:33 PM
diesel_fireman20001's Avatar
Default Front axle poping
My front axle has a popping sound whenever i'm in 4x4 (all ratios). It doesn't do it any other time. I will be doing some work to her this weekend and wanted to know what I should check.
Thanks,
Dan
Old Dec 10, 2009 | 08:53 PM
ja-mudder's Avatar
u joints 1st slip colar and fork arm 2nd (this is what actully switches the truck to 4x4) the fork is on the shaft of the vacume motor and slides the collor over the spline of the axal and the pinon to lock it all together if the shaft on the vacume motor is bent it will not go in 4x4 or get stuck in 4x4 or pop in and out,
1st off tho if you ever pull your outer half shaft on the passanger side be sure you put it in 4x4 first or the collor will fall down and youll bend the shaft of the vac. motor(dont ask me how i know)
Old Dec 10, 2009 | 10:28 PM
Thanks
Old Dec 11, 2009 | 11:29 AM
ben@rdp's Avatar
u joints for sure
Old Dec 28, 2009 | 02:44 PM
Dieselguy's Avatar
I have kinda the same thing going on . when i put it in 4x4 and get things underpressure i have a poping sound also . but if i take it easy it dosent do it . theirs no problem when its in 2 wheel drive. any help would be great.
Old Dec 30, 2009 | 11:29 PM
derek7217's Avatar
dude i just had the same problem with my truck and it was the lower ball joints i thought it was all the problems they were saying but no i took it in and thats what the problem was replaced them and no more popping
Old Dec 31, 2009 | 12:08 AM
It turns out it is something in my transfer case.... guess I will be tearing into it in the spring. Have been told by a backyard mechanic friend of mine that it is eithor a warn out shift fork of a worn out tailshaft bearing.
Old Dec 31, 2009 | 05:09 AM
turbo20psi's Avatar
Heres a good site for parts for your transfer case.http://quad4x4.com/Dodge%20Transfer%...0Parts.htm:tu:
shingi
Off Roading
Sep 30, 2015 11:17 AM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
