fuel plate adjust any help
Old Dec 10, 2009 | 08:24 PM
1 bad smoker's Avatar
Default fuel plate adjust any help
I have 1997 3500 dodge dually with ill kinds of stuff done to it now its my turn to work on it its got a #5 plate in it i would like to know how to move it forward and if theres anything else i can do at home and is there a govener spring i can buy that will be better than stock and any help for better fuel milage would be great iam getting 10.9 right now any help,advice,pics that would be great thanks
Old Dec 10, 2009 | 08:47 PM
94cummins's Avatar
there should be two bolts holding the plate on loosen those and move it there is also a 3000 and 4000 gov spring kit for about 450 or 800 i cant remember
Old Dec 10, 2009 | 08:54 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/5-9l-1...te+adjustments try this and see if it helps
Old Dec 10, 2009 | 09:12 PM
12valvetater's Avatar
450 or 800 for a 4k gsk? You need to learn how to shop around.
Old Dec 10, 2009 | 09:21 PM
Shea@L&N Performance's Avatar
FormerVendor
Moving the plate foward is going to hurt your mpg's becuase it will be fueling harder but as long as you can keep your foot out of the throttle you might get the same, but the hard thing is keeping your foot off the go pedal. A 3 or 4k gov. spring kit will wake the truck up alot, I would suggest putting the 4k springs in so you wont have to change it in the future if you plan on more mods. To adjust the fuel plate take off the afc housing, then loosen the two scerws holding the plate(dont take all the way out as you could drop one down into the pump and that would be no bueno) slide plate foward then re tighten the screws. As far as your mpg issue you should be getting better mpg's unless your dogin it all the time. Sounds like your timing has slipped and that could very well cause your mpg issues. I was gettin horrible mileage when I first bought mine then we checked the timing and it had slipped to 11 degrees, stock is around 14. Bump it up to 16 or 16.5 and you should see a drastic improvement. Hope this helps
Old Dec 10, 2009 | 09:23 PM
lodal cummins's Avatar
got my 3K gsk for 95.00 so i think you may have paid too much!!!!
Old Dec 10, 2009 | 09:27 PM
FormerVendor
We can get you a set for $90 shipped, but if you wanna pay $800 we could arrange that also
Old Dec 10, 2009 | 10:16 PM
captain_stabbin's Avatar
Old Dec 11, 2009 | 12:11 AM
Default 1 bad smoker
hay my name is edgar i would love that deal for 90 in stead of 800 hundred my number is 1 702-210-1700 any other advice would be great thanks
Old Dec 11, 2009 | 09:16 AM
94 12valve's Avatar
what other stuff do you have done to it?
