GSK Install Tips
Old Dec 9, 2009 | 09:44 PM
rkadcock's Avatar
N.M. Bombers Director
Default GSK Install Tips
I'm going to do an 4K GSk in my friends truck this weekend, and I've read the instructions both from BD and Pacbrake, and I have a good understanding of what I'm doing but is their any hints that could make this a little easier?
Old Dec 10, 2009 | 08:19 AM
BTI's Avatar
BTI
Might wanna try search......
The same type of question has been asked here alot.
It's an easy job, just take your time.
I put a roll pin punch on the tip of the stud and slide everything out of the pump onto it.
If you do that you can't drop anything in your pump.
BTI
Old Dec 10, 2009 | 09:21 AM
daveO's Avatar
BTI
Just like BTI said, take your time. I did the same thing he did, except I used a long flathead screwdriver, worked like a charm.
Old Dec 10, 2009 | 10:02 AM
Shea@L&N Performance's Avatar
FormerVendor
Recheck over everything a few times and make sure you got everything right, few cold beers wont hurt either
Old Dec 10, 2009 | 10:19 AM
BTI's Avatar
BTI
Just a "few" no more than that until done LOL
I used a pencil magnet to drag the springs etc out onto the punch.
BTI
Old Dec 11, 2009 | 06:48 AM
PhilipR's Avatar
You'll need a pick to scrape the shims off the seats....they like to stick on there.
Old Dec 11, 2009 | 08:54 AM
rkadcock's Avatar
Thanks guys! I'll let you know how it goes latter on today. I plan on doing it in a couple hours once it warms up.
Old Dec 11, 2009 | 09:21 AM
94 12valve's Avatar
I like to do mine through the slot where the fuel plate is, insted of the side plug.
Old Dec 11, 2009 | 02:42 PM
rkadcock's Avatar
I was going to go through the top and not the side. After reading the BD instructions I was sold on doing the whold thing on top of the pump instead of trying to find the side plug and working where I can't see to well
So I'm doing the GSK now and in front of the plug nut on the side, theirs a wire going across blocking me from the nut. Im tempted to cut it and say F it but my luck it'll cost me $1000 to replace if I do that. What is that wire for?
Old Dec 11, 2009 | 03:09 PM
Diesel Nut's Avatar
Its safety wire to keep the other bolts from backing out. Just cut it, you will be fine. If it bothers you get some safety wire and re tie it when you are done.
