boost screw on pump
Old Dec 9, 2009 | 06:42 PM
tltruckparts's Avatar
Default boost screw on pump
on my other cummins motor i have i noticed there is a boost line that goes from th etop of the pump into the block. on my truck it is just plugged off with a plug on the intake manifold. what does this do good or bad any improvements? or should i snag the line and re hook it back up?
thanks
Old Dec 9, 2009 | 11:36 PM
big bad diesel 416's Avatar
Site Sponsor
Turning up the pre 94 Ram diesel injector pump
man you should see a **** load more power your not getting max fule as low boost no air to the AFC as its called means no fule
Old Dec 9, 2009 | 11:54 PM
so i should snag the line of my other motor and use it then? i tried doing that today but with the pump being advanced 1/8" i cant get the screw on so im going to have to unadvance it again which is a pain so i was hoping i wouldnt have to do that
Old Dec 10, 2009 | 12:13 AM
Site Sponsor
or get a 1/8 NPT 90* with a feral fitting and a piece of 1/4 air line and the same to the pump
https://www.dieselbombers.com/1st-ge...tml#post418726
Last edited by big bad diesel 416; Dec 10, 2009 at 12:13 AM. Reason: Automerged Doublepost
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
moneypitk5
Feb 12, 2015 11:01 AM
93cummins12v
Dec 22, 2014 11:06 PM
