headlight problems
Old Dec 9, 2009 | 06:15 PM
dodgeram666's Avatar
Default headlight problems
my headlights are not being cool the are good on low beams but highs are not what the used to be they are duller and arent as high as the should, i did change the bulbs.
anyone know how to help me
Old Dec 9, 2009 | 06:22 PM
wildbill's Avatar
Are the lenses clear, or did they start getting yellow?? Might want to check and have them re-aimed.
Old Dec 9, 2009 | 06:25 PM
no the lenses were replaced with stock replacements but ya ill try to get them aimed thanks man
Old Dec 10, 2009 | 12:49 AM
Thats not really the answer.
Basically, with the way its wired you are not getting a full 12V to the bulbs. At minimum, you need a heavy duty harness with relays - this will provide a full 12 volts to the bulbs.
Other options are converting to sport headlights with have a 9004 and 9007 bulb in each light. Doing this will require a relay and more wiring to each bulb.
Another option is the HID conversion. But, this requires new projector housing from what I understand.
Old Dec 10, 2009 | 01:01 AM
green monster's Avatar
does anyone else offer the heavy duty harness with relays other than lmc truck..
Old Dec 10, 2009 | 01:21 AM
Yes, cant remember right now. But you can wire up your own.
FWIW, I have the LMC harness and its not that bad.
Lots of good info on the Daniel Stern website - Daniel Stern Lighting Consultancy and Supply
check this one out - Daniel Stern Lighting Consultancy and Supply
Bulb connectors - Innovative Wiring - Headlight Parts
Old Dec 10, 2009 | 04:34 PM
12valvetater's Avatar
High beams burn up the switch. I've gone through 2 ill never use the high beams again.
Brody Olson
Chevy/GMC Duramax 06-07 LBZ
Sep 12, 2015 11:01 PM
tom88k5
Jun 16, 2015 12:57 PM
suzan
Dec 2, 2014 03:03 AM
Blue Briar
Oct 5, 2014 08:23 AM
