hard start.
Old Dec 9, 2009 | 04:23 PM
skyjacked84's Avatar
Default hard start.
just with in the last few weeks when i get up an remote start my truck it takes a few time. when i use my key it also takes a few time, could this be that the fuel filter needs to be changed? its not like its really cold here in the mornings. id say low 60's
Old Dec 9, 2009 | 04:30 PM
Randy B's Avatar
Could be the filter. How old is the battery? I just had to replace my battery, started the same way, from a cold start. Took longer to start, Have the battery load tested. Just a thought?
Old Dec 9, 2009 | 10:40 PM
about 3 month old red tops.
Old Dec 10, 2009 | 05:39 AM
Jerroh's Avatar
If the rubber fuel lines havent been changed then chances are they need to be...they will suck air without visible signs of leaking. could be the filter, also u might want to clean the pre filter/ fuel heater screen while u are at it.
Old Dec 10, 2009 | 07:34 AM
STUMPMAN's Avatar
There is a check valve in the Injector pump or lift pump (Somebody will correct me on this) But it could be losing prime, causing the slow start. I've seen exactly what your describing being caused by that.
Old Dec 11, 2009 | 06:39 AM
PhilipR's Avatar
That would be the OFV....you'll need a FP gauge to really diagnose the OFV though.
Old Dec 11, 2009 | 12:17 PM
thanks guys, ill look into it more this weekend an let yall know.
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
trab123
Feb 9, 2015 09:44 AM
