Where Do EGTs Turn Into $$$
Old Dec 9, 2009 | 02:09 PM
jfoose's Avatar
Default Where Do EGTs Turn Into $$$
Just got my EGT, Boost, and Trans temp gauges in last weekend. My question is, with my pyro situated between cylinders 3 and 4 what does everyone think my safe EGT limit should be? I'm seeing some 1000 to 1200s right now during short WOT bursts, 600-900 normal around town and highway driving??
What is a safe trans temperature?
Thanks.
Old Dec 9, 2009 | 02:11 PM
wildbill's Avatar
Same as I'm seeing stock. 1350 and under for an extended period.
Old Dec 9, 2009 | 02:24 PM
Ive always thought it was 1250F sustained.
The melting point of aluminum is 1250F. You also have account for measuring error. Id rather err on the side of caution when it comes to a piston meltdown.
Old Dec 9, 2009 | 02:29 PM
jfoose's Avatar
What are everyones thoughts on the trans temperature? I am using a genos garage acu temp adapter that wraps around the trans line so I'm looking for a baseline. It's running around 130-140 around town, and 120-130 open highway??
Old Dec 9, 2009 | 06:59 PM
cerberus60's Avatar
Cummins claims they tested the +04.5 trucks at 1450 degrees EGT's and they are rated to run there. Keep it at or under 1300 sustained and you should be good. FYI, that is with stock timing. Once you modify the timing all bets are off.
Trans temps in the hot line generally run 160-180, on mine at least. As low as 140 when it gets really cold. Operating temp is 140-230 degrees, if your in that range its good.
The Accu-Temp is not so Accu from what I have seen. Most seem to run 20-30 percent cooler than actual from posted temps.
Old Dec 9, 2009 | 07:02 PM
wildbill's Avatar
On days like today, my trans temps never went over 110, and the sensor is in the pan.
Old Dec 9, 2009 | 07:07 PM
2500HeavyDuty's Avatar
different motor, but dmax are rated for 1350 sustained. they do have aluminum heads, but it dissapates heat very well.
i have burried my pyro on many occasions ive considered getting a 2000* one before cause ive kept it hammerd for a while.
id be more concerned about the wheter the turbo can take it or not not the block.
Old Dec 9, 2009 | 08:04 PM
jfoose's Avatar
Thanks for all the good information. Does anyone know what the timing advance on the different smarty levels are? I'm not running anything stacked on the smarty, but I also only run level three due to my stocker tranny. Anyone know.
Old Dec 9, 2009 | 08:09 PM
well bassically adding timing will lower egt's and increase fuel economy. theres alot of playing around though to get it the way you want.
Old Dec 9, 2009 | 08:10 PM
cerberus60's Avatar
Jeez, thats not even av alid comparison considering the day and where you are. "Days like today" indeed!!
I think this is the non-TNT version but it has slipped my mind.
#1 12*
#4 16*
#3 18*
#2 21*
