Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
6.0 running ruff after cold start any help?
Old Dec 9, 2009 | 09:14 AM
bill g's Avatar
Default 6.0 running ruff after cold start any help?
my 6.0 diesel runs really ruff when starting in cold weather. it smooths out after a few miles once it worms up. i have a banks 6 gun on it with pda and checked for code and get nothing. does any one know how to fix it.
Old Dec 9, 2009 | 08:54 PM
04redstroker's Avatar
What weight oil are you runnin? Have you gotten the updated fash for it? My truck runs a little rough when its cold from the heavier weight oil that i run, but when i got the new flach it helped alot
Old Dec 10, 2009 | 06:58 AM
trailerbuilder's Avatar
Old Dec 10, 2009 | 07:48 AM
bill g's Avatar
i run 15-40 rps it runs rough below 60 deg like its running out of fuel. i tried replaceing
the egr valve and changed all filters and still runs like crap till it w/up
Old Dec 10, 2009 | 04:26 PM
Try switchin to a lower weight oil, like a 10w30 or even 5w30 if its real cold where you are and also synthetic. Seems to do the trick for most people. Also getting the most recent flash is supposed to help with cold start up. I run a semi syn 15w40 that i get free from work and mine runs rough till i bump the idle up in the morning.
Old Dec 10, 2009 | 07:00 PM
bill g's Avatar
thanks i'll give that a try
Old Dec 10, 2009 | 07:35 PM
atrd86's Avatar
I would suggest the oil for sure especially if it gets pretty cold where you are and if you already did the fuel filters, maybe you should check the codes and see if any of your injectors or the FICM are going south.
Old Dec 12, 2009 | 08:38 PM
bill g's Avatar
thanks ichecked for codes and got nothing i'm going to change the oil and see if that helps
Cavnar
Sep 9, 2015 07:18 PM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
dandbmcc
Mar 14, 2015 11:05 PM
custom7.3
Nov 23, 2014 10:44 PM
