Shaving The Timing Advance Piston
Old Dec 8, 2009 | 06:15 PM
RSWORDS's Avatar
Default Shaving The Timing Advance Piston
Any thoughts? Should get a larger range of advance, alowing you to run a lower "set" timing and have more advance...
Old Dec 8, 2009 | 09:15 PM
tower_ofpower's Avatar
technically it could work but i wouldnt know how to determine when you've gone too far. it may end negating itself as the pin may end up binding in the cam plate
Old Dec 8, 2009 | 09:31 PM
Richie O's Avatar
I like the idea if it worked. I don't mind advanced timing on the upper rpm end but low revs.
Old Dec 9, 2009 | 12:11 PM
Alwaysworking's Avatar
why shave the piston when you can add travel to it.
Old Dec 9, 2009 | 04:07 PM
RSWORDS's Avatar
how much advance will it give (what range of advance)
Old Dec 9, 2009 | 11:03 PM
seandonato73's Avatar
what a guy got what we all need!!
Old Dec 10, 2009 | 05:12 PM
SteveinAz's Avatar
Ok, I'm listening. Where, when, how much? Install directions?
Old Dec 10, 2009 | 05:49 PM
oklahoma_6speed's Avatar
Old Dec 10, 2009 | 08:17 PM
goes on the ksb system, available now, $105 shipped. directions included.
under 30 minutes to install, and adds 1 MM of timing.
Old Dec 10, 2009 | 09:02 PM
SOLD! hahaha... would you be able to get your hands on the spring and sweeten the deal? i get paid friday. i'll get in touch with you bud and we can further discuss this as business shouldnt be discussed in the threads
