99 dodge idles but no go!!!
Old Dec 8, 2009 | 01:09 PM
roy1979's Avatar
Default 99 dodge idles but no go!!!
my 99 24v 3500 is pretty much stock except a intake and exhaust. it has 250k. i use it for a daily work truck. i have been making my own biodiesel at home, i know i know everybody has an opionion about this but i ran the same stuff in my 12v for 2 years with no problems except the occasional fuel filter clog. when i start up it idles just fine but when i step on the throttle it starts sputtering and choking out. everybody that i know who has or knows about diesels in general just shruggs thier shoulders and says "i dunno". fuel filter is clean thought maybe the injectors were clogged. i am not a diesel dummy but am clueless on some things, this bieng one of them. please please help i need to get this truck back on the road. im having to drive my 2wd toyota and i cant haul nearly as much. thanks if you can give me some help
Old Dec 8, 2009 | 01:31 PM
12vcummins96's Avatar
injector pump and the ecm are bad i just did this for another friend exact same thing
Old Dec 8, 2009 | 01:44 PM
roy1979's Avatar
what is the ecm? still have the old 12v truck if i want to continue using my biofuel would i be better off with the mecanical 12v or will the new pump stand up to the biofuel?
Old Dec 8, 2009 | 01:47 PM
the computer and bio diesel will not harm a vp 44 clogged fuel filters will
Old Dec 8, 2009 | 01:54 PM
roy1979's Avatar
oh. we have kept clean ones in there but when we started looking closer the pump says remanufactured so its been replaced before so maybe got a bad one. the entire computer is screwed? crap that sux
Old Dec 8, 2009 | 01:56 PM
yep sorry you will have to get it from the dealer becuase it has to be flashed for your truck
Old Dec 8, 2009 | 02:04 PM
roy1979's Avatar
ok man thx ill let you know how it all turns out
Old Dec 8, 2009 | 02:05 PM
cool glad i could help
Old Dec 8, 2009 | 02:18 PM
Smokem's Avatar
Do you have any fault codes? I will tell you this now, I have had 5 sets of injectors come through that have used oil based bio fuel, you would only need to see the inside of one to change your opinion about using it.
Old Dec 8, 2009 | 08:29 PM
Sawman's Avatar
if you have to buy a ecm you can buy them aftermarket and then take to dodge for flashing. I saved about $400 by ordering ecm at oreilly auto parts( mine is 99 to if they tell you they can get tell them to keep looking they sell them in clinton tn). the reason i told you this is i have a friend in pa they told him they could not get them
