timing
Old Dec 8, 2009 | 12:35 PM
jake 94's Avatar
Default timing
can you guys tell me how to adjust the timing on my truck and what i should put it to i was thinking about advancing it 15 degrees or so any input is good and another question is when i start my truck hot or cold a have to just barely tap the throttle how could i fix this is it just idle that needs adjusting. thanks guys
Old Dec 8, 2009 | 01:59 PM
12vcummins96's Avatar
16 is a good number
TSB 18-10-94 Rev. A
hope this helps
Old Dec 8, 2009 | 03:43 PM
PhilipR's Avatar
Hotcummins covered the timing....but yes a bump in the idle should fix the cold start. It should be 800-850 in neutral with the A/C in your case. Using a little pedal is not bad though with the mechanical pumped trucks. Lower your visor and it will say on the cold start instructions to push the pedal some.
Old Dec 8, 2009 | 08:08 PM
jake 94's Avatar
thanks guys. im lookin for a bearing kit for my tranny you guys know where i could get a kit for cheap?
Old Dec 9, 2009 | 01:05 AM
Adjusting idle - Ram Diesel Problems
Old Dec 9, 2009 | 06:35 AM
PhilipR's Avatar
Post for a quote from the sponsors here.....
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
91 7three
Nov 14, 2014 10:37 PM
jjbced
Oct 26, 2014 09:09 PM
