For Sale: 1985 Ford F250 Diesel Dually $800
Old Dec 8, 2009 | 12:11 AM
ZTMIKE's Avatar
Default For Sale: 1985 Ford F250 Diesel Dually $800
I have a 1985 Ford F250 6.9L international diesel for sale, it needs some work done and I just don't feel like messing with it.
It needs gaskets done, (trans gasket, small oil leak, not sure what is causing it as I haven't looked) needs valve covers gasket, and a bottom radiator hose (small leak) and the truck drains the batteries, I haven't been able to trace it down so I have just been disconnecting the main battery. (you can hook up a shut off switch to the battery if you don't feel like tracing it down either) And the tires will need to be replaced shortly. The steering is off a bit and only the speed odometer works. Has 2 diesel tanks and they both work, and you would be hard pressed to find any rust on this truck.
Other than that, it seems fine, shifts a little rough from when you first take off, but I think it only does it when the engine is cold. I haven't really drove it that much lately, and its been sitting in my garage.
I have replaced the windshield and fixed the leak, I've spray painted some spots and the hood, changed the oil with Mobil 1 Delvac 15w 40 with a good Ford oil filter (no cheap ****) and I've got some oil left over. Replaced the 2 taillights, took out the sagging headliner (its bare metal now). Replaced the broken heater core heat works great now. Had a flush done at work for the power steering fluid. Ghetto rigged a front passenger side headlight and replaced some bulbs that were out.
Along with some other stuff that I can't remember. The mileage is not known for sure as the trucks odometer doesn't have a 6th digit, as it is now I believe it reads 80,000 miles or so.
I have the title and I'm asking $800 firm pick up only, or buyer pays and sets up shipping.
I can post pictures probably tomorrow. Truck does run/drive.
I don't come on this site much more, so if I don't reply back to you if you PM me, send me a email via: mpj1984@gmail.com
I'm located in Michigan City, IN
Old Jan 27, 2010 | 12:38 AM
Uncle Bubba's Avatar
Is this item still available or is this thread ready to be closed out.
ish1521
Aug 26, 2015 08:42 PM
Dec 10, 2014 08:10 AM
Sculpturesylvan
Oct 18, 2014 10:19 PM
