injector problem
Old Dec 7, 2009 | 10:29 AM
rlncoal57's Avatar
Default injector problem
i have a 03 lb7 with 110,000 miles on it. truck still runs strong but smokes at idel. scowering the fourms i now know that i have an injector problem... i checked my oil today ad it smells badley like diesel fuel.. can this be good for the barings in the lower end? after i change injectors am i going to have to worry about other problems in the future due to this? any advice will help thanks again
Old Dec 7, 2009 | 11:58 AM
2500HeavyDuty's Avatar
get that to the dealer asap. the diesel fuel is not good for the bearings.
there is still a 7year/200kmile warrenty for the injectors and you should be coverd
Old Dec 7, 2009 | 01:44 PM
rlncoal57's Avatar
kewll thanks ive heard from a couple people about the 200,000 mile warente but wasent posative ive got an appt. for the truck to go in this friday. do u think i should take off my edge n cold air intake?
Old Dec 7, 2009 | 02:44 PM
take off the edge, they didnt give me any problems with my CAI or exhaust, but if u want to be on the safe side its only a 5 minute swap to switch back to stock
Old Dec 9, 2009 | 12:41 AM
Ballz04lb7's Avatar
i just got my injectors replaced an they do tests on your injectors an if it passes them you get them covered for free an if they see you had a chip on it they wont replace them
Old Dec 16, 2009 | 07:31 PM
rlncoal57's Avatar
Default shes all fixed!
well its been about a week but just wanted to give yu guys an update... got all 8 injectors coverd under warente. also why they were in there they found 2 fuel lines that had cracks in them that would probaley explane why i kept loseing fuel presure!!!!! so they replaced it all... thanks again for the info and elp!!!!!
Old Dec 22, 2009 | 10:42 PM
skuzlb7's Avatar
i just got my 03 lb7 back from the dealer, i took it in for the same problem - smoke at idle only when at operating temp though, they told me since I only have 1, maybe 2 injectors leaking from the nozzle it is not covered by the 7/200k warranty, they say the only way they warranty them is if they are leaking from the upper part of the injector body which causes fuel to enter the oil. I might wait a month, dump some diesel into my oil and take it in again. what do you guys think? my warranty is over in june.
Old Dec 22, 2009 | 11:29 PM
diesel in the oil is usually a sure thing, have you tried other dealerships?
Old Dec 24, 2009 | 12:48 AM
DuramaxakaDTD's Avatar
I just replaced my injectors which were not under warranty and it was a bitch! not really just takes too much time
Old Dec 24, 2009 | 03:32 AM
tell me about it, done it about 5 times
