need some help
Old Dec 6, 2009 | 02:13 PM
z440racer's Avatar
Default need some help
my 94 cummins has an aftermarket bigger turbo with 190 hp injector nozzles and the nv4500 tranny it has a 2 inch leveling kit with 35" mickey thompsan atz tires on eagle rims but my problem consists when i give it a lot of throttle in lower gears it backfires and spit and sputters if you try to get on it in L and 1 gear i know it isnt topping out either in the rpms so if you could let me know it would be awesome
Old Dec 6, 2009 | 02:34 PM
12valvetater's Avatar
First what the heck are you trying to say? Second if I am understanding you at all id say its a mix of low timing and governor springs.
Old Dec 6, 2009 | 02:36 PM
z440racer's Avatar
ok i was just letting you know what all my truck had done completly before i asked a question but i was thinking the same thing how do i adjust my timing or will i have to take it somewhere im pretty up to date on all that because i have tore down a few cummins for rebuilds just always back to factory
Old Dec 6, 2009 | 02:41 PM
You will need a timing kit. Don't go any higher than 16.5* of a stock headgasket with no rings or studs. Its a very simple job if you know what your doing. The hardest part for most is finding tdc. With stock GSK you'll only fuel to 23-2400.
Old Dec 6, 2009 | 03:01 PM
z440racer's Avatar
ok thanks a lot man i am going to try to get to this soon my buddy has a timing tool for it so i will use his but man thanks for your quick response
