shut off solenoid
Old Dec 5, 2009 | 12:15 PM
cumminskid92's Avatar
Default shut off solenoid
I think i need injectors. my shut off solenoid went out so i put a new one in it. it only lasted a few hours and it is out again. i have my full fuel cranked to the max with stock injectors. does anybody make a better solenoid or is there anything else i can do untill i can afford injectors
Old Dec 5, 2009 | 12:44 PM
big bad diesel 416's Avatar
Site Sponsor
it may take 2,3,4,5,6 shut off solenoids to get a good one
Old Dec 5, 2009 | 04:11 PM
921stgen's Avatar
Yes you need to turn your fuel down. When you get on it really hard and let off it is when the tip of the selonoid plunger get tore. Or you can remove it one more time and gut it (remove spring and plunger) and reinstall it. Hook up a pull cable on the manual shutoff on the side of ve. Pic of manual shutoff labled kill switch if you belong to dtr. pump.Message - Dodge Diesel, Diesel Truck Resource Galleries
Old Dec 5, 2009 | 06:43 PM
BC847's Avatar
When you do go to larger injectors, you'll most likely be able to run the modified solenoid again with no problem.
camp9
Mar 25, 2017 07:40 AM
bosse777
Sep 28, 2015 05:38 AM
cdhearn
Chevy/GMC Duramax 01-04 LB7
Jun 17, 2015 11:15 AM
nevadagramm
Oct 17, 2014 07:59 PM
pstack
Oct 16, 2014 04:25 PM
