shaving stock fuel pin
Old Dec 5, 2009 | 12:32 AM
dodgeflatbed's Avatar
Default shaving stock fuel pin
i am looking to shave my own fuel pin, and was wondering if anyone had any advice or instructions? or if there is a video around somewhere.....
Old Dec 5, 2009 | 11:03 AM
muskrat's Avatar
As far as advice i have none, since I've never ground a stock fuel pin. But if you have a basic understanding of how you VE pump works, and why you are ginding your pin, you should do fine. Here is a link also for instruction. Good luck.
http://www.dieseltruckresource.com/d....html?t=154086
Remember even if you totaly grind too much which IMO, you realy can't other than for over-weakening the pin, You can always get out a welder and add back on. Just take your time.
Old Dec 5, 2009 | 04:59 PM
stillcummin's Avatar
I wouldnt grind like he did.The pin can only go down so far and it bottoms out.he probably doesent eben get use out of his "new ramp".unless you shaved the base of the pin.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
