14cm Turbo housing and 60mm housing
Old Dec 4, 2009 | 12:33 PM
dodgeflatbed's Avatar
Default 14cm Turbo housing and 60mm housing
I was thinking about ordering a 60mm housing also, and a 14cm turbo housing. If you have one, or both of this i was wondering if you happy with the results of these two, and what did you gain from them...?
also, i was wondering if anyone has a picture of a grinded fuel pin that i may look at, or if ya'll know of any online or have any suggestions for grinding my fuel pin
Old Dec 4, 2009 | 01:12 PM
muskrat's Avatar
What do you plan on doing with your truck?
Sorry, as far as HP goals and what you use your truck for. If you plan on mildly modifying your truck and want a more enjoyable ride, it is a pretty good upgrade, it spools much faster and makes more boost than the stock set-up. If you plan on bigger injectors and/or other mods in the future, I'd consider saving up for a whole different turbo.
Old Dec 4, 2009 | 02:31 PM
i plan for it to be a daily driver/work truck... i just wanna squeeze as much HP as i can into it, and make it smoke a little, nothing to extreme.
Old Dec 4, 2009 | 02:58 PM
muskrat's Avatar
Then you'll probably like it. I like mine for now, but I know I'm going bigger in the near(ish) future.
D-350 dually
Apr 11, 2015 11:38 PM
