Clamping off Wategate line on HX35?
Old Dec 4, 2009 | 12:10 PM
CumminsCrazed's Avatar
Default Clamping off Wategate line on HX35?
Hey guys, a buddy of mine told me to clamp off the wastegate line on my HX35 and i will get more boost. Couple questions...
1. Does this work?
2. Will it overboost my truck and stretch head studs, blow head gasket or overspin turbo?
3. I already see 35-37 lbs of boost, how much more will this net me if its safe?
4. Is this recommended?
Old Dec 4, 2009 | 12:15 PM
NCFPD's Avatar
I wouldnt do it if your already getting 35+psi of boost im pretty sure the hx35 is only rated to 35 but there are some guys running higher. Also how do you get 35psi already the factory waste gate is set to like 22.8 or somthing like that i think your waste gate might already be stuck closed
But if it aint broken and it works LEAVE IT ALONE
Old Dec 4, 2009 | 12:18 PM
IDK, bone stock i got 16-18 PSI, added a boost elbow on stock truck, got 25ish, added edge comp on EZ mode, got 30, tapped wire and now im getting 35-38 PSI, turn comp box off and i see 30.
Old Dec 4, 2009 | 12:50 PM
NCFPD's Avatar
humm I have the quad addr and the highest i have seen is 23 and thats pushing it i might get a lttle higher maybe i have something wrong with my truck
i might try to clamp my line and see if i can get a higher boost if i cant my waste gate might be messed up
oh how much is it noticable having like 22 psi verses going up to 35
Old Dec 4, 2009 | 12:58 PM
turbostang7's Avatar
i don't think anything is wrong with your truck NCFPD, i have the adrenaline running the comp tune and i only see about 23 with spikes up to 25. i put a thread on here and everyone said it was normal. i have heard if you push the HX35 past about 34 35 it only blows hot air and is basicly useless, and you run the risk of overspinning your turbo. honestly i wouldn't clamp the line, its there for a reason.
Old Dec 4, 2009 | 01:01 PM
NCFPD's Avatar
ok good to know my stuffs alright yea i would just leave it all alone. And as for crazed up above i dnt think i would clap your line at all your already pushing 35+
Old Dec 4, 2009 | 01:03 PM
cummins_guy's Avatar
we just take the exhaust side off and weld the flap so it doesn't open anymore
Old Dec 4, 2009 | 05:29 PM
DB Admin's Avatar
Banned
Your Sig...
silencer ring MIA
WOW.
Anyway ... with out a boost fooler if you block the waste gate you will throw over boost codes , you can get a boost fooler stand alone MAP for like $40 or a edge ez or another programmer , im pretty sure all programmers and chips have built in boost foolers.
with stock injectors your not going to make enough boost to hurt anything so blocking the waste gate wouldnt be dangerious , but your not going to gain much of anything , so you got more boost ...nope , boost is pressure ....you got more pressure ...you dont want more pressure you want more air flow , upgrading your intake and exhaust manifolds and turbo is the route you want to go, simply increasing the pressure is not what you want.
Old Dec 4, 2009 | 06:06 PM
12vcummins96's Avatar
Originally Posted by DieselMinded
Your Sig...
WOW.
very nice chad
Old Dec 4, 2009 | 06:32 PM
NCFPD's Avatar
when i said if it aint broke leave it alon i was refering to the terbo and messing with it when its already making sufficiante enough boost pressure why mess with it and as for my silencer ring it was missing when i bought it so in return i havnt touched it
