injector nozzels?
Old Dec 3, 2009 | 07:14 PM
wisconsin redneck's Avatar
Default injector nozzels?
are they good/bad? should i get all new injectors or nozzels? my injectors are leakin and when the trucks off air gets into the lines and its a pitta to start.. also runs rough for 10 or so seconds... or can i get new seals and washers? would that fix it?
thanks guys
Old Dec 4, 2009 | 12:00 AM
stkdram55's Avatar
Sounds more like a cracked fuel line not an injector problem...Check all your rubber fuel lines.
But if you have the money get the full bodies not nozzles. that way you can just put them in and not have to worry about taking the nozzle and having them put in bodies and pop tested
