towing setup
Old Dec 2, 2009 | 10:19 PM
warhammercustoms's Avatar
Default towing setup
I'm new to the diesel scene and I was wondering what mods are good for a 1992 (1st gen) cummins diesel.
3200 governor spring?
fuel pin?
turn up the fuel screw?
or is that not the best for towing?
Old Dec 2, 2009 | 11:24 PM
Uncle Bubba's Avatar
Hey Bud, Welcome to the site. I moved your post in here to the tech area's because it's where your gonna get your best answers to this specific question.
Old Dec 2, 2009 | 11:57 PM
peobryant's Avatar
Gauges
4" exhaust
366 spring
DennyT cone
Low pressure piston lift pump
370 injectors
Super HX40
Pump tuning
That is a very good towing setup. George Peterson runs that in his 1st Gen when he tows. If you have an automatic, a good converter is definitely needed though.
Edit: I forgot a few things
A set of Coolertubz would also help cool EGT's.
Ang like 91 12valve said, a better air filter, or BHAF would also do you good.
Old Dec 3, 2009 | 09:35 AM
91 12valve's Avatar
open air filter or cold air is it a manuel or automatic the automatics are not the best in the world
Old Dec 3, 2009 | 09:54 AM
wildbill's Avatar
*moved here
Old Dec 3, 2009 | 08:09 PM
sorry it's an automatic
Old Dec 3, 2009 | 09:18 PM
peobryant's Avatar
If it's an auto, at the very least get a converter. I recommend Dave Goerend, but there are others out there as well.
But, since the thread is asking about a towing setup, I will recommend you have Dave build you a 47rh. Our transmissions don't have lockup, which is kind of a pain. Converting to a lockup tranny, would be better in every way, they your current one. That or a 5spd.
Old Dec 3, 2009 | 09:34 PM
A 47RH? What truck is that out of?
If I were to go with a manual trans what would be the better choice?
Thanks for all the help
Anyone have an opinion on this transmission setup?
Dodge A518/618 47/48 RH/RE "BadBoy" for CUMMINS
Last edited by warhammercustoms; Dec 3, 2009 at 09:34 PM. Reason: Automerged Doublepost
Old Dec 4, 2009 | 12:50 AM
peobryant's Avatar
A 47rh would be found in either a '94 or '95 Dodge Cummins. A '96 would have and up, would have electrically controlled transmissions, and you don't want that.
If I were going to convert to a manual, it would be an NV4500. The only problem they have, is with the 5th gear nut, but that is an easy fix, especially for a conversion. There are also numerous parts available for it.
If you want a 6 speed, you could swap either an NV5600, or G56 in, but both would be much more expensive, and the NV4500 has proven to be a more reliable tranny.
I don't know about that "BadBoy" tranny. Never heard of it. If I were going to have someone touch my Dodge transmission, it would be either Dave Goerend or Cousin Billy. And since Cousin Billy is a local guy (who just happens to use Goerend parts) Dave would be the way to go for you.
Old Dec 4, 2009 | 01:39 PM
The_Head's Avatar
Interesting, never seen those guys before.
Sep 27, 2015 02:10 PM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
klu408
Apr 26, 2015 07:52 PM
amztroyer
5.9L 24V Performance
Dec 22, 2014 10:30 PM
Sep 29, 2014 12:40 PM
