oil pressure drop
Old Dec 2, 2009 | 09:20 PM
12valve801's Avatar
Default oil pressure drop
wondering if anyone could help me out with this . sometimes when i'm driving all of a sudden the check gauges light comes on and the oil pressure is all the way down . and then comes right back up. usually happens at idle and randomly only happens every once in a while.
i was just thinking the sending unit might be bad ..
any ideas?
Old Dec 2, 2009 | 09:36 PM
ArizonaRedneck's Avatar
sounds like you found a good place to start had that problem before on some of the heavy equip we run after the butt pucker factor goes away usually found a bad sending unit or bad ground and to make sure it is not bad oil press can double check by using a regular oil pressure gauge
Old Dec 2, 2009 | 10:06 PM
Shea@L&N Performance's Avatar
FormerVendor
Start off with the basic stuff, have you checked the oil lately
Old Dec 3, 2009 | 02:07 PM
12.valve.hauler's Avatar
i would check the oil first and after that check the grounds and conectors. the go to the sending unit and so on ans so forth
Old Feb 26, 2010 | 01:33 AM
IPSC_GUY's Avatar
Default Problem solved?
Ok I have a 98 5.9 liter Cummings 2500 that is doing EXACTLY the same thing. I also have a 96 5.9 liter Cummings 2500 that has NEVER done this even once.
So did anyone figure this out?
IPSC_GUY
SIERRA II ALPHA
Old Feb 26, 2010 | 06:34 AM
96blackcloud's Avatar
the factory oil pressure gauges in the cluster tend to...well suck.. check your oil make sure its all there, check ground all else fails cant go wrong with a mechanical gauge same thing happens to my truck every once in awhile
Old Feb 26, 2010 | 07:58 AM
wisconsin redneck's Avatar
IPSC_GUY
SIERRA II ALPHA
Cummins dude.... no g
thanks for serving btw
Old Feb 26, 2010 | 11:41 AM
IPSC_GUY's Avatar
Where is the ground located at? So the indicator itself is a bad design and the sender sucks on top of that? I will say this, it is unnerving to say the least. Ya never wanna see something like oil pressure fall to zero...
IPSC_GUY
SIERRA II ALPHA
Durtyd09
Nov 11, 2015 01:43 PM
jhprice
Mar 29, 2015 09:36 PM
Detroitpower
Mar 7, 2015 09:31 AM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
