valve cover gaskets
Old Dec 2, 2009 | 09:10 PM
Rexy's Avatar
Default valve cover gaskets
truck has over 215,000 miles and has started to show some weakness. Was going to start with checking the gap on the valves. When i pull the valve covers will i need new gaskets or can a guy usually re-use them?
Old Dec 2, 2009 | 09:26 PM
Lil Red Express's Avatar
If they are original you will need new ones. Valve are set at .010 intake and .020 exhaust. Check all of the boost hose clamps from the turbo to the intake.
Old Dec 2, 2009 | 09:36 PM
midnite><og's Avatar
i owuldnt re-use them, espcially after so many miles.. shouldnt be to expensive.. jsut remember to not tighten them down to much, or you will have some nasty oil leaks
Old Dec 2, 2009 | 09:39 PM
Pyro690's Avatar
x2
Rock Auto has them for bout $3.50 each.
Old Dec 2, 2009 | 09:56 PM
Rexy's Avatar
ok thanks
Old Dec 3, 2009 | 02:06 PM
12.valve.hauler's Avatar
i just redone my valve covers and tried to reuse the gaskets. didnt go to well. you can get them at advance auto for 5 a piece.
Old Dec 3, 2009 | 08:30 PM
STOVEPIPE's Avatar
just picked some up for $27 for all 6 thats with tax, guess I should of looked around some more
Old Dec 4, 2009 | 08:43 AM
bigtim44's Avatar
My dodge has about the same mileage ,had to change out the rocker gaskets at the end of the summer the old ones were cooked hard and leaking.
put some fresh gaskets on.
Old Dec 4, 2009 | 12:10 PM
biged681985's Avatar
i would go with genuine cummins gaskets. i bought some from a local parts store, and 4 of them split in two.
if there not leaking now, and still seem to be soft, i would just reuse them myself.
good luck
mrh1282
For Sale
Jul 20, 2015 04:27 PM
LTreis702
Feb 14, 2015 12:52 PM
cmalson
Nov 29, 2014 12:57 PM
woodsman27
Oct 26, 2014 02:13 AM
flogrownstroker
Oct 6, 2014 01:19 PM
