turbo
Old Dec 2, 2009 | 10:24 AM
91 12valve's Avatar
Default turbo
would i be able to tell if i just put on a different turbo housing on my stock turbo
Old Dec 2, 2009 | 12:15 PM
Heavy's Avatar
Yea man you want to go with a 14 or 16 mm housing it will let your truck spool up quite a bit faster and you play with ip a little
hey man i meant 14 or 16 cm housing my bad
Old Dec 3, 2009 | 09:19 AM
91 12valve's Avatar
well i wasnt sure if it would make that much difference but that would be way cheaper than a turbo thanks man
Old Dec 3, 2009 | 06:32 PM
peobryant's Avatar
If your truck is an intercooled '91, then it will have the huge, laggy 21cm housing. If that's the case, then a smaller housing will make the truck much more enjoyable to drive. If you have a non I/C truck though, you'll have an 18.5 cm housing, and I would recommend saving up for another turbo, rather than changing the housing.
Old Dec 3, 2009 | 08:58 PM
91 12valve's Avatar
yeah it is intercooled i was looking on pure diesel power and the 16cm housing said it was for 94-97 non waste gate but it should fit a first gen turbo wouldnt
Old Dec 3, 2009 | 10:48 PM
seandonato73's Avatar
bought a 16cm for my 90 it helped spool time a good bit. didn't have the money for a turbo quite yet
yes it will, thats where i got mine
Last edited by seandonato73; Dec 3, 2009 at 10:48 PM. Reason: Automerged Doublepost
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
