Want to put a '95 hx35w on my '93 Anyone tried?
Old Dec 1, 2009 | 03:09 PM
mspeer7's Avatar
Default Want to put a '95 hx35w on my '93 Anyone tried?
Hello All, I have a '93 D250 2wd, 5spd. I have the 3200 spring for it and a turbo off of a '95 that is waste gated. While I have it down for the gov spring I'd like to install the turbo. My question is will it fit without any modifications?? I have a turbo off of a 6bta out of a F700 240hp but the exhaust side is to long and the waste gate acuator gets in the way of the intercooler piping. The one off the 2nd gen dodges has a different exhaust housing and looks shorter. When I say longer/shorter, I mean from the bearing housing towards the fire wall. I only have a little bit of room to move the exhaust backwards. Has anyone installed one like this????
Thanks in advance!!!!
Old Dec 1, 2009 | 04:07 PM
ArizonaRedneck's Avatar
go to search at top of page and enter hx35w turbo on first gen then it will take you to first gen site check out first page if this dont work let me know
Old Dec 2, 2009 | 08:26 AM
peobryant's Avatar
Yes, quite a few people have installed an HX35 on a 1st Gen. Like said, do a search, but from the top of my head I seem to recall you have to move the exhaust back an inch or two. Otherwise it shouldn't be a problem. Unless you have luck like mine...
Old Dec 2, 2009 | 04:26 PM
RSWORDS's Avatar
Make sure it has the correct housing on it, other wise you will be fabing a down pipe.
Browe347
Sep 30, 2014 11:35 PM
