trans issues? or just the nature of the TC
Old Dec 1, 2009 | 10:32 AM
biged681985's Avatar
Default trans issues? or just the nature of the TC
my truck has a problem strating off with a trailer, at 18,000 pounds, my truck wont move it till the motor is revved up. once i get it goin and get the torque converter locked in 2nd, it pulls like it should. is this my trans slipping untill the TC locks, or is it just the nature of the goerends TC. we pulled the same load with dads, and takeing off in his 89 ford idi, it didnt have as much trouble taking off with it as mine did. but once moving mine kicked its *** pulling. so if any one could help, id appreciate it
Old Dec 1, 2009 | 11:34 AM
94dizzyram's Avatar
I have had my factory tranny do this to me before. I was towing a trackhoe. Probably about 18 or 19,000. It didnt seem to do any permanent damge, but i am sure it wasnt good for it.
Old Dec 1, 2009 | 09:01 PM
that was gross weight, including the truck and trailer. just curios if it might be the higher stall TC, or trans.
Old Dec 1, 2009 | 09:29 PM
cummins95's Avatar
well if its a higher stall tc then that would be my guess, i've never heard anything bad about goerend so i imagine thats just how its designed. might wanna have the bands adjusted just in case tho
Old Dec 2, 2009 | 10:34 AM
just checked the fluid it is still the same color red, and does not smell burnt. i think im gonna drain some fluid and change out the screen, since im got to put a trans temp sensor in.
any recomendations on anything to check while im in there?
Last edited by biged681985; Dec 2, 2009 at 10:34 AM. Reason: Automerged Doublepost
Old Dec 2, 2009 | 07:13 PM
turbo20psi's Avatar
Adjust the bands while you are in there.Check for metal shavens,make sure any and all bolt are tight.The banks tq does the same thing, high stall mine about 1700 rpm with a heavy load.
Old Dec 2, 2009 | 07:18 PM
12vcummins96's Avatar
its the converter ed mine does it to
Old Dec 2, 2009 | 07:54 PM
dieseldrillsgt's Avatar
Default 2nd gen dodge ram transmission issues
hey all. i have a 1995.5 ram 3500, and i have had all kinds of issues with the automatic tranny, it was having all kinds of shifting problems like the torque conv wouldnt lock up. i was told several times to change the tps, and did at 150.00+ a pop, i finally got pissed. i did alot of reserch and was finally able to isolate the issue. on the 2nd gen dodge rams with automatics there is a frequency glitch in the PCM that controls the TPS. there is a ground problem. and fortunatly there is a fix. its made by BD engine brake INC. its a wire that you splice into the pcm harness and then ground. i did the fix today and it runs and shifts like new. you can check out the web site at BD Power - The Leaders in Diesel Performance. i got my part from the amcco xmission dealer was like only 30.00 bucks. also you may wanna check the kick down cable they fray really easy. and finally check the small male end of the throttle assembly that goes into the TPS, if its worn at all it will throw the xmission of sequence. hope that helps.
Dieseldrillsgt.
Jake9473
Jul 22, 2018 08:19 AM
drgracen
Oct 5, 2015 09:13 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
Cutlass26
Mar 22, 2015 05:46 PM
Polaris04
Dec 1, 2014 08:27 AM
