ceased 12 valve
Old Dec 1, 2009 | 09:37 AM
12/24valve's Avatar
Default ceased 12 valve
does anyone have any idea on how to get a 12 valve unceased
Old Dec 1, 2009 | 10:06 AM
biged681985's Avatar
depends on what caused it, u can try spining it backwards, u might5 have to loosen all the main bolts if it spun a crank shaft bearing, if it filled the piston full of coolant from a crack cylinder or a head gasket failure, u would have to pull an injector. it all depends on what caused it. good luck
Old Dec 1, 2009 | 10:22 AM
12/24valve's Avatar
well it was took out of a wrecked truck and they pulled it out and it seat all winter and then i bought it from them cause it ceased up just by seating
Old Dec 1, 2009 | 01:18 PM
DIESELDENT's Avatar
Welcome to db
Good luck with the engine, try posting in the 12V section
Old Dec 1, 2009 | 02:21 PM
01trailerpuller's Avatar
If it has ceased do to weather it might have some rust between the piston and cyclinder wall. I would tear it down and do at complete rebuild.
Old Dec 1, 2009 | 02:31 PM
wt_offroad's Avatar
pull the head and use wd40 or other pentrating oil to get the rust freed up. had a 22r that did the same thing. i just pulled the spark plugs and filled the cylinders with wd40 and let it sit for a few days. then used a breaker bar to get it turning and then put 10k on the engine befor it lost a rod. it was in my 82 rock crawler. good luck.
Old Dec 1, 2009 | 03:38 PM
K50's Avatar
K50
x2 I would also recommend this. Best way to ensure that the engine will run smoothly.
Old Dec 1, 2009 | 04:32 PM
mishkaya's Avatar
Hope you get your issues resolved!
Old Dec 2, 2009 | 03:43 AM
97cummins's Avatar
Old Dec 2, 2009 | 04:30 AM
12vcummins96's Avatar
