Transmission Swap
Old Nov 29, 2009 | 05:58 PM
Bad93Cummins's Avatar
Default Transmission Swap
Anyone done a A518 to NV4500 swap in their cummins? im getting one in about 2 weeks and just looking for a good write up or some good info on the swap.
Also wandering, it doesn't have the clutch pedel and cable, where can I get that from? Also can I use the starter on my A518 or do I have to get one for the NV4500?(came off a 97' Cummins 2wd).
Old Nov 29, 2009 | 06:49 PM
RSWORDS's Avatar
You need the adaptor plate (plate between the engine and tranny) and starter from the 2nd gen. You will need the clutch assembely and all related parts also from a 1st gen.
Old Nov 29, 2009 | 06:51 PM
He say's its has everthing but the starter and the clutch pedel with the cable going to the tranny.
Old Nov 30, 2009 | 04:42 PM
RSWORDS's Avatar
Make SURE it includes the adaptor plate, it is a totally different part then the bell housing, most tranny dont come with it.
Old Nov 30, 2009 | 05:16 PM
muskrat's Avatar
I apoligize, I don't want to scew up this thread, But has anybody ever heard of these guys? I only found out about em cause, I was researching the swap.
Dodge A518/618 47/48 RH/RE "BadBoy" for CUMMINS
Old Nov 30, 2009 | 06:51 PM
RSWORDS's Avatar
few things that pop out at me... Things that make me say stay away...
We had a customer that was making 6-700hp out of a Cummins, Towed a 25,000 lb trailer
Don't see anyone towing 25,000lbs with that much power... You would need some HUGE (read laggy) turbos to keep that thing cool.
Power Capacity: 800 ft-lbs of torque, 800 HP
So which is it? 800hp is about 1600ft/lbs and 800 ft.lbs is about 400hp...'
The earliest version of the RH trans did not have a lockup converter In 94 a lockup converter was introduced tote RH
The pre-94 trannys were not lock-up trannys...
I would stay away, they obviously do not know diesel trannys... Do it once, do it right. Go with a name brand proven builder.
Old Nov 30, 2009 | 07:02 PM
muskrat's Avatar
That makes sence. They boast a pretty bad *** tranny and I have never heard of them before.
Old Dec 2, 2009 | 12:07 PM
Ill get a picture of the tranny and everthing and see if it comes with adaptor plate and everthing I need. I do know i will need clutch pedel and clutch pedel ***.
Here's 2 picture's of everthing coming with the tranny
So is everthing their or do I still need item's? I foud clutch pedel and hydro's for $100 shipped.
Last edited by Bad93Cummins; Dec 2, 2009 at 12:07 PM. Reason: Automerged Doublepost
Old Dec 2, 2009 | 04:24 PM
RSWORDS's Avatar
You will find all sorts of little things while doing it. But you have teh basics! Get a GOOD clutch while you are doing it. No point in pulling it out twice!
Old Dec 2, 2009 | 07:38 PM
RSWORDS's Avatar
One thing I thought of, your auto has a flex plate that will not work with you new manual, you need a flywheel from the donor truck.
