Fuel Pin Videos
Old Nov 29, 2009 | 01:59 PM
muskrat's Avatar
You Tube Fuel Pin Videos
If you're looking into getting a fuel pin and want to see what they can do, I'm posting some good stuff to watch. M&H Inc is one of our sponsors and have a selection of profiles that allow you to tune your truck to your liking.
dyno run of a stock 1991 non intercooled dodge ram 250 diesel with a getrag 5 speed 3:54 gears. completly stock except 4 inch strait pipe. 73HP/140TQ at the wheels with stock fuel pin at its deepes...
dyno run of a stock 1991 non intercooled dodge ram 250 diesel with a getrag 5 speed 3:54 gears. 4 inch strait pipe. 165HP/443TQ at the wheels with M&H Inc M1 fuel pin
dyno run of a stock 1991 non intercooled dodge ram 250 diesel with a getrag 5 speed 3:54 gears. 4 inch strait pipe. 176HP/473TQ at the wheels with M&H Inc M fuel pin
dyno run of a stock 1991 non intercooled dodge ram 250 diesel with a getrag 5 speed 3:54 gears. 4 inch strait pipe. 187HP/524TQ at the wheels with M&H Inc M3 fuel pin
dyno run of a stock 1991 non intercooled dodge ram 250 diesel with a getrag 5 speed 3:54 gears. 4 inch strait pipe. 185HP/518TQ at the wheels with M&H Inc M4 fuel pin
dyno run of a stock 1991 non intercooled dodge ram 250 diesel with a getrag 5 speed 3:54 gears. 4 inch strait pipe. 182HP/510TQ at the wheels with M&H Inc M5 fuel pin
Also Here is a DennyT vid, because it too, is a great pin.
Old Nov 29, 2009 | 02:05 PM
RSWORDS's Avatar
What were teh numbers from the dyno?
Old Nov 29, 2009 | 02:12 PM
1st genny nut's Avatar
thts crazy i gotta get me one
Old Nov 29, 2009 | 02:15 PM
muskrat's Avatar
Duh. I'm on it.
Old Nov 29, 2009 | 02:19 PM
FRadisi's Avatar
Definitely one of the first mods I do when I get one
Old Nov 29, 2009 | 02:51 PM
muskrat's Avatar
I coppied the info on each run and I am confused by the numbers made by the stock pin?? must be an error.
Also, notice that the highest numbers made were by the M3 pin, not the M5.
Old Nov 29, 2009 | 02:57 PM
RSWORDS's Avatar
I bet it has to do with over fueling down low.
Old Nov 29, 2009 | 03:20 PM
muskrat's Avatar
Ok, so all of the M&H pins have the same profile @ the deepest point, the different pins are different because of the way they move into the deep part of the pin. A different shaped lip, so to speak. Then it seems that the M3 would probably be the best all around fuel pin because, there is less wasted fuel @ lower boost, and it just moves into full fueling in a more efficent manner.
Old Nov 29, 2009 | 03:46 PM
RSWORDS's Avatar
Yep, and that is why I will be running a M3 next year pulling.
Old Nov 29, 2009 | 04:16 PM
DieselPerformanceGuy's Avatar
alright so what would u guys think, should i ditch my bully dog and get the m&h pin or should i stay with the BD.
Also muskrat what was the next best pin, hp wise.
Never mind its the m4
sorry
Last edited by DieselPerformanceGuy; Nov 29, 2009 at 04:16 PM. Reason: Automerged Doublepost
