new guy hoping for real help
Old Nov 29, 2009 | 12:34 PM
catfishdiesel's Avatar
Default new guy hoping for real help
new to the diesel world, and having problems. 04 duramax (LB7 engine code) engine light on, code says EGR, mechanic says take it off and clean it with carb cleaner. is this good or bad, and where is it located. any help would be appreciated.:
Old Nov 29, 2009 | 12:38 PM
12vcummins96's Avatar
Chevy/GMC Duramax 01-04 LB7 - Diesel Bombers
post it in here you will get more help
Old Nov 29, 2009 | 12:40 PM
muskrat's Avatar
Welcome to Diesel Bombers, dude. Go ahead and post in the correct place and you'll get better answers than a little waving smilie
Chevy/GMC Duramax - Diesel Bombers
Or:Diesel In Distress - Support Ticket - Diesel Bombers
Good luck.
Old Nov 29, 2009 | 01:22 PM
mishkaya's Avatar
Hope you get your issues resolved!
Old Nov 29, 2009 | 01:27 PM
thanks everybody,i re-posted in a differant forum, sorry about that
Old Nov 29, 2009 | 01:32 PM
jbrown1132's Avatar
the 04 lb7 engine didn't have the egr crap. are you sure you have a lb7 or an lly engine? check the 8th digit of your trucks vin # if 1=lb7, if 2=lly. oh yea, welcome!
Old Nov 29, 2009 | 01:40 PM
hey thanks for the reply the 8th digit in the vin is a 1
Old Nov 29, 2009 | 01:49 PM
jbrown1132's Avatar
then your truck does not have the egr. you need to see what codes are active on your truck. you can go to a parts house like advanced auto or autozone, they should be able to check your truck for codes. just write down what codes you see and lets us know.
Old Nov 29, 2009 | 01:58 PM
Default codes
p0307 cylinder 7 misfire p1404 exhaust gas recirculation error egr #2. that was the codes from a oreillys autoparts.
Old Nov 29, 2009 | 02:23 PM
jbrown1132's Avatar
check the wiring harness that is running across the altenator bracket to see if any of the wires have damaged insulation on the which can cause a short. if you find any, you can repair the wires with butt splice stac-on and for added protection against water, use some shrink wrap insulation. this can be found at radio shack. you might find it at orielly's.
