Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
7.3 white smoke
Old Nov 28, 2009 | 03:10 PM
Maverickrider's Avatar
Default Can my 7.3 be sucking air ?
A friend stop by today.! He said my truck could be sucking air? For the reason of white smoke ? But did't say from where? Would anyone Know where to start looking for air leaks ? Are should i use ether to locate ? Thankyou for all ya'lls help
Old Jan 8, 2010 | 03:16 AM
cody73's Avatar
Default air leaks
You should start by checking around the fuel filter cap it may be loose or the seal may be bad. Another place to look is at the two fuel lines coming out of the filter hosing going too the heads check both ends for snugness. Another possibility is that your fuel filter needs replaced. White smoke is only caused by two things "air in fuel, and lack of fuel." I hope this helps solve your problem.
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
mihilo
Sep 16, 2015 10:42 AM
motocox_307
Sep 8, 2015 09:09 AM
Domrig13
Dec 12, 2014 01:24 PM
