Bad Vibration possibly Pinion
Old Nov 27, 2009 | 09:42 PM
LEBF's Avatar
Default Bad Vibration possibly Pinion
My truck has a bad vibration starting @ about 70 and at 75 it will vibrate the rearview off. I changed the U-joints and the carrier bearing seems ok. How do you check the pinion bearing and how do you change the pinion bearing?
Old Nov 27, 2009 | 09:50 PM
wildbill's Avatar
How bout the front drive line?? Remove it, then go from there. Also could be the tires need rebalanced.
Old Nov 29, 2009 | 04:47 PM
LEBF's Avatar
Your right it was the fron shaft. Now that I have narrowed it down to the little ball joint in the middle of the double jointed end, How hard is this to repair. I think I need a new yoke because the ball wore threw the race or can I put a new race in there with some new u-joints and call it good.
Old Dec 8, 2009 | 07:47 PM
ja-mudder's Avatar
glad you were able to do some good problem solving cause the pinon bering is pressed on the pinon shaft so the entire rear end is pulled apart and most of the time the hardening on the pinon shaft comes off and lets the bering move and shift around so you have to replace the ring and pinon too
just so you knoe in the future
Old Dec 9, 2009 | 06:30 AM
PhilipR's Avatar
That's the Cardian Joint....I think you can get a rebuild kit from Rock Auto for it.
Old Dec 11, 2009 | 07:42 PM
LEBF's Avatar
I havent found one for it yet so I am just driving it like it is for now. How hard is it to change the pinion seal on the front dif.
Old Dec 11, 2009 | 08:19 PM
wildbill's Avatar
Not very hard. Easiest to use a slide hammer to pull the seal, then use a big socket to install the new one.
|WYG|SS
Jul 4, 2015 08:31 AM
saranay
Apr 25, 2015 12:34 AM
Feb 5, 2015 12:10 AM
12vbomber
Nov 11, 2014 10:58 AM
findau1
Oct 28, 2014 03:47 PM
