popping is constent
Old Nov 27, 2009 | 08:28 PM
NCFPD's Avatar
Default popping is constent
alright guys the poping has gotten worse and theres still no codes being thrown i have no clue and i cant take the poping any more its doing it constently when in park warmed up and idleing just constent poping i need all the ideas i can get that i can try
Old Nov 27, 2009 | 08:36 PM
mishkaya's Avatar
Not quite sure what you are trying to describe. When did it start exactly?
Old Nov 27, 2009 | 08:49 PM
TwinStackPete379's Avatar
Injector tip?.
Old Nov 27, 2009 | 09:05 PM
NCFPD's Avatar
like when i go for a drive warm it up then i stop put in park let it set for a sec there will be like a pop pop pop kinda like a little back fire coming from my stack and when it pops the rpm drops like just a tad it aint a consten rumble. It did it every once in awhile not often about 4-5 weeks befor my VP went out i replaced it and my lift pump and now it does it more it started off once every couple sec. but now 300 miles later it does it constent almost do you hink it is a bad injector maybe and now that the vp runs good and idels at 900 rpms instead of 800 that its making more preassure how to tell if an injector is bad.
Also whats surging sound like maybe its that but it only does it at idle and i also have my addr. on to thats new but it did it befor the addr and new vp. but man it screams when moving and in gear
Old Nov 27, 2009 | 09:07 PM
mishkaya's Avatar
I'd suggest having your injectors checked...
Old Nov 27, 2009 | 09:11 PM
NCFPD's Avatar
How much are some new ones stock bec. dont think i can run any ones higher than stock with my trans
how do you get them checked can it be done by hooking it up to a computer
Old Nov 27, 2009 | 09:16 PM
mishkaya's Avatar
You'll need to take them to a Diesel shop to have them tested. I believe Scheid is not too far from you. They're in Effingham if I'm not mistaken. They could do that type of service. You can always give them a call at any rate.
Old Nov 27, 2009 | 09:30 PM
NCFPD's Avatar
yea the nerest place to me is 2 hours i am north of st/louis about 2 hours
Old Nov 28, 2009 | 08:52 PM
Codgedodger's Avatar
FormerVendor
50hp injector wont hurt any ghing ive had mine in for 6 months and my auto hasnt slipped once. And you can roll some coal and get about 22mpg too.
Old Nov 28, 2009 | 08:57 PM
NCFPD's Avatar
thats always good my kids are so facinated with the smoke the only time i make it do it is for them
