Have a few codes, need help
Old Jul 28, 2007 | 10:55 AM
06 DIESEL's Avatar
Default Have a few codes, need help
I have three codes and I have been able to identify two of them but the third is not found anywhere.
P-2504 -- high charging system
P-0462 -- Fuel level sending unit colts too low
PD412 -- Unknown
What would cause these codes, I know what caused the P-2504, jumping the loader at work and I think it charged me instead of vise versa. As for the other two, what could have caused them and what are the possible solutions. I am still under warranty and have not done any performance mods yet, so I have a perfect warranty.
Thanks
06 DIESEL
AutoMerged DoublePost
Bump
Old Jul 29, 2007 | 10:39 PM
Super Dave's Avatar
Go to Autozone and have them reset the codes. Then see if they come back. Or you can drive it for a about 5 heat cycles and it may reset itself.
Old Aug 22, 2007 | 06:10 PM
BDPowerDave's Avatar
I did a search and cam up with this thread...
http://www.dieseltruckresource.com/d.../t-146846.html
not much info but you may able to chime in and see what the results were.
Old Aug 22, 2007 | 06:16 PM
06 DIESEL's Avatar
I also found that, I have had no other problems since the codes. :confused:
Old Aug 22, 2007 | 06:17 PM
weird... no mods either huh?
Old Aug 22, 2007 | 06:24 PM
06 DIESEL's Avatar
Not yet, I have them sitting on my desk waiting to install.
Old Aug 22, 2007 | 06:36 PM
This one has me stumped, I will continue to see what I can find for you.
Old Aug 22, 2007 | 06:50 PM
DB Admin's Avatar
Banned
Old Aug 22, 2007 | 06:51 PM
DB Admin's Avatar
Banned
Disconnect your batterys and turn your key on and leave it over night ,
In the moring turn jkey off reconnect batterys Reset APPS and Start it up and Check for codes
DM
Old Aug 22, 2007 | 07:39 PM
06 DIESEL's Avatar
Originally Posted by DieselMinded
When did we get this? That is one more reason that I am glad that I signed up for this site. The only problem is that is does not have the PD412 code.
DM
I have not had any more problems with it, if I throw any more codes with it I will try this but how do you reset APPS and what is it.
