2002 Dodge Ram 2500 Diesel
I have a 2002 Dodge ram 2500 diesel that I am pulling a map and iat sensor code on. My mechanic thinks it is the ECM but is not sure. I only have about 1/4 of the pedal and then nothing happens after that. If anyone has had this problem and could help me I would appreciate it. Thanks
We're only good at saying hi on this forum.
Post your ?? here:24 Valve 2nd Gen Dodge Cummins 98.5-02 - Diesel Bombers You'll more than likley find answers there.
Pull both sensors and clean them with sensor cleaner - not anything else. Next, clear the codes and see what it does. If it is still acts up or the power dies off then you will want to determine if you have any air and enough fuel getting in there.
You need gauges if you don't have them. Having said that, testing the batteries, checking grounds and lastly, getting the ECM overwritten with the stock SMARTY code is probably on the radar.
vududady
For Sale
Apr 15, 2015 12:00 AM
and BTW
