HELP!!!!! 12v Fueling problem
Old Nov 26, 2009 | 12:42 PM
cummins freak's Avatar
Default HELP!!!!! 12v Fueling problem
all I know when I step on it at like 60-65 and try and get it to get moving fast to say 75-80 it just sputters, falls on its face and goes nowhere and has no power....now if I slowly speed up it will go just fine....kind of sounded like it was missing like a gas motor
ps. there is no more black smoke looked to be only a gray/white haze.
I was thinking timing slip...fuel pressure shot, maybe HG blown I dont know????
Old Nov 27, 2009 | 08:23 PM
mspeer7's Avatar
Hey did you find out what the problem is? I just timed my 95 r2500 4x4, installed a new feul plat and a 3 gsk, and now it sounds similar to your problem. My dodge smokes alot and misses. I checked my timing 3 times before I put on the front cover. Have you just done some work to your rig??
Old Nov 27, 2009 | 08:34 PM
TwinStackPete379's Avatar
have you checked your fuel filter?. check Fuel pressure. could be combination of things. start ruling out the easy ones first. Start with filter, inspect lines, fuel heater bowl. ( little filter on bottom could be full of crap.) then if they all check out, you might want to check timing. imo. good luck
Old Nov 27, 2009 | 08:42 PM
monster12valve's Avatar
just happend to me.... same thing. i have a leaking fuel line, between the tank and the rail. i replaced it with rubber. runs perfect now.
Old Nov 27, 2009 | 08:45 PM
12vcummins96's Avatar
u have air in the lines
Old Nov 27, 2009 | 10:40 PM
Shea@L&N Performance's Avatar
FormerVendor
Check all your fuel lines, and maybe crack one of the injector lines just to make sure you dont have any air in it like hotcummins said. Which rearend gears do you have and what rpm are you runnin at 75-80?
Old Dec 1, 2009 | 05:42 PM
i havent had achance to check it but it ran better the other day. I was running like 2300ish RPM's at 75-80 I have 4:10's.
I think it does need a new filter and now that I finally have a garage i can work on it mor regulary.
burndiesel
10
Feb 7, 2023 01:15 AM
Antwhite19
Mar 26, 2020 04:58 PM
Jonrarick
Oct 25, 2016 01:32 PM
jeremy01995
Sep 14, 2015 06:34 PM
big tan snorkel
15
Dec 17, 2014 05:04 PM
