1997 Dodge 2500 4wd Issue
Old Nov 24, 2009 | 09:47 PM
wrench123's Avatar
Default 1997 Dodge 2500 4wd Issue
Hello,
My brother has a 1997 Dodge 2500 4wd with a Cummins and a 5 speed transmission. He has been having trouble with the front axle not engaging for the four wheel drive.I believe it is some sort of vacumn system that actuates the fork to engage the front axle. Summit Racing used to sell a cable of some sort to bypass the vacumn system, or whatever it is exactly, and just actuate the fork manually. Having trouble finding the cable now though, does anybody know of a product like that?
Thanks!
Old Nov 24, 2009 | 10:32 PM
Have a look at this thread:
https://www.dieselbombers.com/12-val...ront-axle.html
Old Nov 26, 2009 | 09:42 AM
country_boy's Avatar
i was having having the same problem with my 94 and thought it was low vaccume pressure. it ended up being the fork was sliding the collar over center and wasnt locking the axels togather. i put a small brass washer on the end of the arm that the fork is on and that seemed to fix it
Old Nov 27, 2009 | 06:12 AM
12.valve.hauler's Avatar
when i had my problem i also checked the vaccum system and the actuator and they were both working good. i had to peplace the u-joints on the front axle to fix the problem. the u joints were wore out and it wasnt letting the axles line up where the sleeve could slide over. if this is your problem make sure to check the splines on the axles, they may have to be cleaned up with a file.
RedChevy44
Apr 21, 2015 05:47 AM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Nov 4, 2014 08:10 AM
Oct 24, 2014 02:50 PM
