idleing problems
Old Nov 24, 2009 | 04:35 PM
NCFPD's Avatar
Default idleing problems
Man i have been having all kinds of problems. Alright what would cause my truck to idle high like after it warms up i idles normal at 800 but after it warms up or has been sitting for a bit it idles at like 900or a tad bit higher
Old Nov 24, 2009 | 06:07 PM
ja-mudder's Avatar
900 is normal
Im not for sure why but i guess the new vp you just put in?? the new computer on it my have something to do with it or the fact you have a good pump?? Because I idal at 900 just to easy your mind
Old Nov 24, 2009 | 06:32 PM
NCFPD's Avatar
well thats great now do you have any ideas on my popping back fireing rough running cummins motor at idle its like it is missing
Could that popping be the quadzilla or is it a sensor like the crank or cam or could it be the lifters needing adjusted and will that roughness hurt any thing i dont have any problems while driveing just at idle
Old Nov 24, 2009 | 07:12 PM
ja-mudder's Avatar
You have not tryed unhooking the Quadzilla yet First thing you ever do is elimanate the computer made power. but after that.
I know valves on my bikes will do this when theres problems, if you have over 180000 you should chek them anyways. it easy after you find TDC
but other than that id be checking injectors
Old Nov 24, 2009 | 07:34 PM
NCFPD's Avatar
it has about 170000 on it so just valve adjustment could fix it were do i learn how to do the valves is there directions so to speak on DB
Old Nov 24, 2009 | 08:04 PM
ja-mudder's Avatar
im not sure around here, but if you ever do any of your own work you should all ready have a chiltns of hayns manual there cheep(20$) and at any good parts store and it has almost everything you need for anything on your truck, I have seen this kinda problems with a 12 valve that a bud brought to me to fix and I could not tell you what fix it for sure cause we replaced the head gasket so anything up top was checked and cleaned up
Old Nov 24, 2009 | 08:14 PM
NCFPD's Avatar
oh well i still have to get a manuel but i am praying that it aint somthing exspensive bec. i cant afford anything eles
Old Nov 24, 2009 | 08:27 PM
ja-mudder's Avatar
no adjusting valves is just time, if all is good with them Id atleast check them. but first get rid of the programer and see what that dose im guessing its that, and probly just the vp44 responce to the chip if it is iv never seen any long term problems with it. but get a manual too
Old Nov 24, 2009 | 09:01 PM
NCFPD's Avatar
yea well i went out and warmed the truck up with the chip unploged and it threw 6 codes i cleared them started it and the codes never came back and it never poped once then after a bit i hooked the quad back up still no codes started it and let it warmed up more and still nothing so as of now its not doing it still jumps between 900 and 1k grand rpms but runs smooth now the motor wasnt to its full running temp but it was about 160temp wise
Old Nov 24, 2009 | 09:11 PM
I very much doubt valves are the problem - but since you asked, there are instructions here:
B Series Valve Adjustment
