apps adj
Old Nov 24, 2009 | 11:11 AM
crane's Avatar
Default apps adj
were can I find pics of the apps adjustment? want to do it have noticed a dead pedal
Old Nov 24, 2009 | 11:29 AM
Have you scanned for codes? I would do that first.
Youll find a procedure here: https://www.dieselbombers.com/5-9l-2...s-i-bored.html
Ive never seen any pics of this
Old Nov 24, 2009 | 11:58 AM
crane's Avatar
not yet it only happens every once in a while
Old Nov 24, 2009 | 06:10 PM
ja-mudder's Avatar
scan first DO NOT play with the apps unless your 100% sure its out of wack Iv seen friends adjust there apps and cause more problems and have to replacce it.
Old Nov 24, 2009 | 06:20 PM
Uncle Bubba's Avatar
The first step is to check the voltage on the APPS to be sure it is out of adjustment. If it's not then you don't have to mess with it after that.
Old Nov 26, 2009 | 10:49 AM
Mopar1973Man's Avatar
So very true... If error codes are already present from the APPS sensor then adjustment is not going to fix it. So replacement is the next option...
Dead pedal is caused by 2 things...
1. APPS sensor which always throws a code! (P0121, P0122 or P0123)
2. Dieing VP44 which might or might not throw codes...
If you adjust a wore out APPS you might find the voltage unstable and you might have the wrong start on the idle validation switches (2 of them!)
Old Nov 29, 2009 | 10:27 AM
RAW's Avatar
RAW
As requested by some, here are pictures of an APPS adjustment:
First Off, this is the APPS. The black cover in the center of the picture
This is what it looks like with the black cover removed. It is held on with two plastic rivets. One on the front hiding behind the radiator hose, and the other is on top.
With the air box removed, the PCM is visible
After squeezing the back half of the connector, the connector cover is removed. I used half a paper clip to back probe the wire and take my reading.
This is my original voltage reading, as said in the instructions, I wrote that number down.
After removing the 6 - 10mm head bolts and turning the APPS, here is the sticker with the specification for voltage.
I adjusted the APPS until the voltage at the wire matched the sticker voltage. I only loosened each of the two Torx20 head screws about 3/4 of a turn.
Old Nov 29, 2009 | 06:56 PM
Why is everyone measuring the voltage at the PCM??? The ECM is what controls the engine and idle, etc...
Old Dec 5, 2009 | 11:40 AM
sledwrecker's Avatar
Check out this web site very informative. Home
Old Dec 6, 2009 | 08:26 PM
ja-mudder's Avatar
This is why Id look when he wright ya
you can get a different reading at the pcm when the ecm is where you should check it
Good catch Mopar1973
