issue after issue
Old Nov 24, 2009 | 05:36 AM
monster12valve's Avatar
Default issue after issue
so i put new fuel lines on my truck... primed the fuel system (2 hours later) i fired the truck up and it ran ruff so i cracked each injector till it was spraying fuel and the idle smoothed out. so i took it for a ride and ran great for about 5 min.... now it idles good but if i were to push the throttle pedal in allitle bit and then release my foot off the pedal fast the truck stalls. but it only does it in gear... in park it does not stall at all. any ideas?
Old Nov 24, 2009 | 08:32 AM
daveO's Avatar
My truck would do this every once in a while when it was cold out and the truck wasn't warmed up yet. I figured out the idle speed was set too low.
Old Nov 24, 2009 | 04:09 PM
bled the system again.... she is running like a champ now.... knock on wood!
Old Nov 24, 2009 | 05:39 PM
tower_ofpower's Avatar
deffinately make sure the idle is set right; this is a typical symptom of an idle setting that's too low
Diesel_Daddy6.0
Nov 12, 2015 09:33 PM
Diesel_Daddy6.0
Sep 23, 2015 03:12 AM
dskewes14
Sep 14, 2015 09:19 AM
JKinni
13
Sep 5, 2015 11:09 PM
Oct 23, 2014 08:10 AM
